Getting discouraged slow piece of cr.....!!!
I would agree the power is off. Should be 112-113mph depending on air and probably run out if the no around 23-24psi in good air and be trapping 121-122mph. I would look at the valvetrain and converter. 4600-5200 it should be very strong. If you're over 5200 any time but out the back end you probably have the wrong converter.
It would be interesting to see what your combo would do at 28psi. I think you are leaving a ton on the table just running 18psi with those heads.
He'd be out of turbo before 5000rpm at 28psi
Would a larger turbo be a better match for the engine combo? Cam specs aren't given though.
Maybe get the car to run what it should with the current turbo first then look at changing it. Converter is a mystery and so is the valvetrain.
Something is definitely way off. I'm running a similar combo...Champion ported irons, 6057 turbo, mild roller (206/206 .465 lift on 112 centers) 2800 stall LU converter. Stock bottom end. Best time 10.92@125.17 on 22lbs boost.
Fresh 109 with 206/210 roller Lonnie stg 1 2800 Edge TT 42lb 15 row SLIC MT 255/60-15
RA .146
60ft 1.837
330ft 5.153
660ft 7.981
MPH 86.47
1000 10.451
1320 12.571
MPH 106.27
All five time slips 1/8 was identical 21 lb boost no KR 5gl C-16 7gl 92 Was running 12.90 class hoping to get it in the 11.90 class Alky is in the works
Sounds like you need to take some time to get that car dialed in. Plenty of people here to help, but they need real data. Like a full time slip and log files. Otherwise your just going to be tuning screws on guesswork hoping to go fast before you blow it up.
I am going to the dyno in the folowing weeks will keep you guys posted!
That's very impressive. What the heck was the weight?
