Getting out of Turbo Buicks (for now). All must go.
Updated list
109 blocks (one standard but will need overbore)
(one .030 over)
$300 and $100 respectively
2 turbo cranks $125 each
Champion Iron heads (1 is brand new, never run) - $700 - Sale Pending
Stock Upper Plenum - $30
Spearco Intercooler (the kind they put in the hot-air conversion kits) - $100
3.5" MAF and MAF Translator - $150 Sale Pending
.020 JE Forged pistons w/Rings - $300
.030 Forged Pistons (TRWs) on 2 dot rods - $100 (these got dinged in shipping a little bit I can send some close-up pics) - Sale Pending
5 – stock Buick TR pistons and 2 dot rods - $75
Gauge pod - single A-Pillar $ 15
ECM - $75
ATR PITBULL chip for #52 injectors - $25
Casper's Electronics LC2 wiring harness for hybrid/race installations - $375
Ported stock intake - $250
TCI 2004R tranny - $400
12" 2800 stall convertor - $150
Stock Fuel rail - $25 - Sale Pending
Crank Sensor - $20
Cam Sensor - $40
Stock up pipe - $15
3” SS Downpipe (parts) This is a 3” BGC DP w/o the elbow. Great for building your own DP - $100
Ported Stock DP elbow - $25
Stock DP - $15
Stock Crossover pipe with Deltagate flange - $10
3” “Stubby” DP elbow with wastegate - $100
Front engine cover - $25
Stock Headers – w/crossover - $100
Ported stock TB - $40 - Sale Pending
Turbo mounting bracket - $40
Starter - $10
Flex Plate - $20
Billet main caps (centers)– $100
Stock I/C fan - $20
Oil Pan - $35
Coilpack and ignition module - $100
Autometer Pro-Comp Ultra-lite gauges - $350 (will not part out at this time)
THESE ARE NEW IN THE BOX!!
3-3/8” Speedo
3-3/8” Tach
2-5/8” H20 Temp
2-5/8” Oil Pressure
2-5/8” Volt Meter
2-5/8” Fuel Level
Turbolink software v.2.1 – $50
Casper’s Cam sensor tool – $20 - Sale Pending
Are the cranks std./std., if so do they need grind or just polish?
Let me take a closer look at 'em and I'll get back to you. One is still in my block (no rods or anything hooked to it, just put it in there to protect it).
What kind of converter? And is it still for sale? How many miles?/ 1/4 miles passes? Pictures please. tonysturbo@yahoo.com
Sorry to say that I don't know all that much about it. It's in the chassis right now. When I pull it, I'll post some pics. I never raced it. Less than 1000 miles under my foot. Before that, who knows?
A couple of addtions-
Qboost in-car boost controller. NEW in original package with instructions - $40
If you need any of the brackets and miscellaneous sensors and such for an
LC2 let me know what you need. I should have 1 of everything.
3" SS test pipe with flange - $40
Driver's side header - welded - $40
Stock Heater lines - $25
2- Wastegate actuators - 1 is stock the other is modifed for adjustable boost - $15 each
Brackets
I could use the alternator/AC brackets. I think there are three different ones.
Updated list
Here's what's left and a few new additions...
Pics of everything (I think) except the blocks and cranks are here--> click on the tach!
(one .030 over)
Ported Stock Upper Plenum - $30
ECM - $75
Crank Sensor - $20
Cam Sensor - $40
Stock up pipe - $15
Stock DP - $15
Flex Plate - $20
Pro Gram Billet main caps - NEW in box-(centers)– $100
Stock I/C fan - $20
Oil Pan - $35
3-3/8” Speedo
3-3/8” Tach
2-5/8” H20 Temp
2-5/8” Oil Pressure
2-5/8” Volt Meter
2-5/8” Fuel Level
2 sets of A/C –alternator brackets - $35 each set
Oil pump - $10
Stock oil dipstick and tube - $10
Sensors – TPS, MAP, IAC, IAT etc. – Whole batch - $10 Good for spares!
Balancer Pulley and water pump pulley - $20
Plugs, Plug wires and Oil filter (Plugs and filter are new) - $10
2 – double roller timing chain sets - $10 each
Turbo bracket (the one shaped like a question mark) - $40
2-3/4” I.D. Downpipe – mild steel. – see pics - free if you pay shipping
Fel-Pro gasket set #2700 - $15
Fel-Pro valve cover gaskets #1600 - $5
Poston’s front cover and rear main seals - $10
Stock Hard vacuum lines - $15
DS intercooler bracket - $15
You never got back with me on the cranks. Are they STD/STD if so will they have to be ground or just polished. I've got aguy that may want both.
I'll get back to you as soon as I can. One is still in the block that's sitting in my chassis. The other is in another block. I'll have to take 'em and get 'em mic'd so I can properly represent them. Please be patient.
I work two jobs and have two kids under the age of 8. Not making excuses but that'll give you some idea of my limited time for all of this stuff.
Richard, I got the UPS shipping notice on the dual fan set-up. I appreciate it and can't wait to have a cool running and looking Buick.
