Dave Simpkins
- Mar 17, 2002
Has anyone tried making a S1 bottom end more like a S2 ?
That is to say, milling the S1 block to accept 4 bolt main caps at#2 and#3mains (just like a S2). The obstacles that I see here are the oil pick-up hole in the block at the #2 main and the dipstick hole into the side of the block at the #3 main.
Im thinking the oil pick up can be overcome by doing a regular cut into the block/web at #2 for the 4 bolt design cap and then milling the cap for a sleeve that would pass through a "corner" of the cap and then break out into the original pick up passage. The sleeve would be welded or staked to secure it. I think this way the #2 cap could be removed without disturbing the oil pick up, and the oil pick up would remain pretty much original. An alternative to this would be to cut into the bulge on the inside wll of the block, that is the uptake oil passage going to the front of the block (oil pump intake). A tube fabricated with the flat pad and 2 fastener holes identical the the stock pick up at the #2 /pan rail could be threaded and secured into the passage ahead of the original location, sort of half way between the stock location and the back of the #1 cap. Ummm. not sure about clearning the rods ??
The dipstick hole could be welded or tapped and bolted shut, then the milling of the #3 web would go on as normal for the 4 bolt cap at that location.
A modified oil pan (a 2 piece tube welded into the side of the pan) and a lengthened dip and modified header bolt mounting bracket should work there. The sleeved together 2 piece tube would make for esay removal of the pan, as the short end of the tube would remain on the pan and the longer end would come off as the stock dip tube does.
Then ... just like doing the girdle deal ... ARP studs, and line bore if needed and line hone for sure. This would stiffen up the bottom end of the S1 for less weight than a girdle and 'bout the same or less mill time. Caps from Pro-gram Eng. are the only ones I've heard of... are there any other manufacturers making 4 bolt steel caps for the wheezer blocks?
Anybody tried this or some variation of it. I figured girdles are for fat ladies.
