Needing a little info on several sets of old stock Gm Cam bearings I have. I found the pt# listed in the Power Source on pg167 as;
0.539 Bearing Cam Front Pt# 123441 Front cam bearing for 1976 and newer V6 engines, no split (pereferred design)
Also found a note on page 84 that states;
Heavy-Duty Cam Bearings
Buick offers a set of H/D cam bearings that may be preferred for H/d use because they are made of a harder, more durable material & have a 0.060 hole instead of a slot for the oil transfer. All bearings in the set are 0.740" wide, which is the demension of the #1 bearing in production.
My question is, could I use the GM H/D Cam bearing that measure 0.740" wide in all jouranls on an 1984 4.1 production block?
