Anthony P
sharing knowledge with those who care to listen
- Jan 24, 2007
Did GM produce headlight bezels molded in black ABS - before production shifted to Canada?
the original bezels on the 87 GN were molded in grey ABS then painted black. The same for the later made in Canada black bezels - molded in grey ABS, painted black, and had the Made in Canada sticker attached. These later bezels had the rear extended "tabs" around the headlight openings to help with the sagging.
not sure if this bezel is really a GM part or an aftermarket one. while it has all these molding data impressions, it seems to be molded in black ABS vs molded in grey ABS and painted black.
wondering if this bezel might be one of the first aftermarket bezels made by Paul Castle - World of MotorWorks and first shown at Richard Clark's get together in 2008. And then at some point, someone put it in a GM box. I've been looking for pictures of those but have not found any from that day or later from the 2008 GS Nat's. There are plenty of threads noting they are molded in black so there is no worry about the "black" fading to show the underlying grey ABS material. I researched that Epitome was also purporting to make bezels in the 2008 time frame, even took advanced payment for orders, but those never materialized.
this bezel looks like the original bezel with the absence of those longer tabs. the angled mold lines at the side marker light are also just like the GM versions (original US made and the later Made in Canada versions). there is an aftermarket version made today where these molding lines are straight up & down vs. angled like the original GM.
got this from a supporting vendor here. came in a correct GM bezel box albeit the GM labels - both part label and warehouse order distribution label were removed from the box.
I just don't know if those early reproduction headlight bezels (and grilles) from either World of Motorworks or the 2009(?) GoodMark version were molded in black ABS AND also had the GM part #'s and mold data.
I can always scuff and spray with SEM Trim Black to make a matching pair of first version, US made, bezels.
Thoughts?
Thoughts?
