GM307C Gas Tank and Double Pumper
monte4ever
Has anyone used the Spectra replacement gas tank (GM307C) for the Turbo Regal with a double pumper setup? If so who's double pumper did you use?
I have the spectra tank and a Red's DP, and the opening is pretty much the same- the pumps are a tight fit, but they do go in :D
I have a spectra tank that has the small dog dish ,RA duel pumps will fit in both tanks the dog dish baffel and the steel baffel that looks like the original turbo tank,the dog dish has a tendency to squish the pump filters..LOOK INSIDE THE TANK AND POSTION FILTERS ACCORDINGLY
Thank you for replying. I bought a DP fuel pump and the pumps go in until it reaches the fuel level float arm electronics box on the return line. I just wanted to be sure that I did have the correct tank. Do either one of yal have a link to where I can get a Red's or RA setup just in case all else fails?
