Gn Backspacing
87GnWon
I'm looking for a set of drag wheels but I'm unsure on what backspacing to get. What is everyone running and what tire size?
I'd like to go as wide as I can with the stock rear and without the fender lips rolled.
I'm running 275/65R15 MT Drag Radials mounted on a set of 15x8 Centerlines with 4" backspacing. Fits good, up under the the body and about 3/4" off the frame. I do have airbags for the track. I haven't experienced any fender rub, but I am cautious of how I cross uneven pavement.
same for me. Weld wheels for the track with 4" BS and no rubbing.
I put on a set of ProStars, 15x8/3.5bs with 275/60's and I'm getting a tiny bit of rub on the outer drivers side from the inner fender lip on big bumps.
need air bags to cure that some cars rearend are not centered perfect
