gn blackout trim color?
cougarmtr
does anyone know where i can buy the spraypaint for the blackout trim such as handles, front and rear window trim etc...? THANKS
Any part store that carries automotive paint will have it. It has a name, but I cant remember it. Just tell them you want GM trim and accessory paint. It is semi gloss, or satin I do believe. It is making me mad that as I type this it is not coming to me....:mad::mad::mad:
:biggrin:
I have tried a bunch of paints over the years and have found this to work best. It's more likely because it has Ceramic in it which makes it harder and holds up better to rock chips on the wheel well mouldings better.
Here is the info:
Dupli-color
(Low gloss black) - DE-1634
<- says this on the cap!
On the can it says, Engine Enamel with Ceramic.
This is a near perfect match to the original color and its stronger. All the trim on my white T-Type is done with this paint.
Scot W.
