Well maybe we will pop off the manifold to see what blew into the lifter valley.
Not having had a head gasket go poof before, I am making a suppostion that that was the case since TurboLink didn't indicate any severe ingition retard, only a drop in boost from 22-23 to 15 PSI. Actually that was the only abnormal statistic in the whole run...the drop in boost pressure. Does this seem like the case?
As for the converter issue, I previously had a PTS 2800 stall and the mile per hour was not any better with the TA49 than with the PT61, and my 60' times went from 1.6-1.7 to 2.1's. There was some tuning issues and definitely underconvertered for the PT61. Well I put in a PTS 3200 and while the track was slick the 60's improved to 1.8's. Each run the 02's were in the high 700's to low 800's and I kept advancing the timing and boost to 26 advance and 23PSI, when the the car laid down at mid track, with the probable head gasket problem. The previous run was 25 degrees of advance and 22PSI. and the car only turned a 12.30 @ 115.2mph. Shouldn't the PT61 be making my car turn 120+? This makes me think that the motor was getting tired. What do you think Razor?
