Engine (was rebuilt 3/07 but has spun bearings disassembled 10/08)
3.8L 109 Block bored .030”
Stock turbo crank .020”/.020”
Stock Turbo Rods
TRW/Speed Pro Forged pistons (.030”)
Stock Main caps w/ ARP Studs
Stock Un-ported 8445 heads w/ 100lb springs (rebuilt and resurfaced 3/07)
Stock Rocker shafts and arms
Stock front cover w/ rebuilt oil pump (had 40psi cold and 18-20psi hot idle oil psi)
$800 obo Will not ship engine!!
Accessory Drive
Alternator-$50
Main accessory bracket-$50
AC Delete Pulley-$30
Power Steering Pump and pulley-$50
Water pump and pulley-$35
Tensioner and idler pulley-$20
Turbo Balancer and pulley-$100
Intercooler fan-$40
Serpentine Belt-$5
Hot side parts
Stock Manifolds and crossover (resurfaced and cracks repaired 8/08)-$100
Turbonetics TE-44 .63 AR, doesn’t smoke but should rebuild due to too much shaft play(up and down)-$200
3” Custom Downpipe w/ HKS wastegate w/ 20psi spring. Comes with 3” Custom Cat. Will bolt up to Single cat Fbody exhaust systems(PM for more info) WILL NOT FIT TTA’s, only Buick headed 3rd gen applications!!-$350
GN Test Pipe-$30
Cold Side parts
Stock Intercooler w/ Duttweiller neck modification (comes with hoses)- $125
3” Chrome MAF Pipe w/hoses (shortened a buick one to work in Third Gen)-$50
2.5” Chrome Up Pipe (drilled for single nozzle AlkyControl Kit)-$25
Stock Un-ported Lower intake manifold-$50
Kenne Bell 70mm upper plenum and throttle body combo (comes w/ hose and sensors)-$400
RJC powerplate for KB and Accufab Plenums-$50
Electronics
Stock 86/87 MAF-50
Cam Sensor-$60
Ignition Control Module and Coil pack (both bought 9/08 from AutoZone)-$100
Kirban Spark Plug Wires-$40
55# Siemens Low Impedance Injectors-$200
Modified Low Impedance ECM (Done by quad Air)-$150
TurboTweak 93 Street Chip and Alky Chips by Eric Marshall-$90
Crank Sensor (bought 8/07 from NAPA)-$40
Injector harness-$25
Misc Parts
Engine Mounts-$30
TTA Frame Pads-$50
Stock Fuel Rail w/ bosch adjustable Fuel Pressure Regulator-$50
Kenne Bell Hood Mount FP Gauge (Missing Hood Mount)-$50
TTA Radiator Hoses-$20
Vacuum Block and hoses-$50
Heater Core Lines-$20
Stock Turbo Rods
Accessory Drive
Alternator-$50
Intercooler fan-$40
Serpentine Belt-$5
Hot side parts
GN Test Pipe-$30
Cold Side parts
Electronics
Stock 86/87 MAF-50
Cam Sensor-$60
Misc Parts
Engine Mounts-$30
TTA Frame Pads-$50
