GN parts for Sale
87 GN WE2
New and used NOS parts for sale. If you are interested email me at 87gnx231@gmail.com
Shipping will be from Canada using UPS and will be extra. Thanks
Direct replacement Walker exhaust for 87 GN includes muffler , two tail pipes, clamps and used pipe from cat to axle pipes. $140
1-New Nos parking lights $95
2-New Pypes exhaust tail pipes $55
2- Used original 87 rear GN brake drums and shoes with hardware kit $50
2- New master cylinder rear bleeder extension screws $5
1-New Gates belt tensioner $120
1-New Cam sensor with oring $180
1-Used Cam sensor works great has 96k on part $80
1-Complete set Kirbans rear seat braces with hardware $50
1-Used 87 intercooler, tested $50
1-Used 87 intercooler fan $20
1-New set of fuel lines over tank $35
1-New GM timing cover $130
1-Complete original air box with hose and KN air filter $100
1-New washer bottle $10
1-New Nos coolant bottle with cap $25
1-New Nos upper and lower rad hoses $90
1-New reproduction outer window moulding $75
1-Used intercooler shroud $10
1-Pair New NOS door air vents $65
1-New Nos Ac Delco heater core $90
1-New Ac Delco window motor $20
1-Used exhaust elbow off turbo $25
2-Used inlet turbo bells $15 each
1-New pair reproduction black door handles $55
1-Used Pvc block $5
1-New AC Delco A/C relay $5
1-Used Nos wastegate $20
1-New Nos power antenna gm part#88891017 $100
2-Used 87 T tops with key $130
1-New AC Delco analog fuel sending unit $140
2-New Nos 3.8 hood badges $60
16-New Nos lug nuts not reproductions $65
1-Set of New Nos emblems two fender (grand national) and two fender (intercooled) $170
1-Used nos coil pack $25
1-New passenger window switch $10
1-New door lock switch $25
1-Used set of 4 Nos grand national floor mats $45
1-New AC delco set new pvc check valves (1-two way) and (2-one way) $10
3-New AC delco new oil filters (1-pf47) and (1-pf52) $10
1-New Nos antenna nut $5
1-New rebuilt vacuum master cylinder $25
1-New Nos set of four GN wheel center caps $135
2-New Fuel door bumpers and 1-hood insulation plug $5
2-New visor plugs $5
1-NewThrottle rod clip $5
2-Waste gate filters $2
2-New Nos door mirror gaskets $10
1-New Black intercooler clamp $2
1-New ECM repair plug $10
9-Repair belts for Delco tape deck $10
6-New R44ts spark plugs $10
1-New Crank sensor repair plug $10
1-New Nos Breather filter elbow $10
3-New Back glass interior molding clip $10
1-New AC Delco TCC solenoid $85
1-New AC Delco antenna bracket $10
1-Delco cd player (year 2000) with harness adapter to GN radio harness $55
1-Delco cd player (year 1998) no harness $40
1-1987 GM factory spec manual on GN’s $15
1-Turbo buick repair manual on CD $15
1-New Nos Ttop gaskets still in original boxes $450
1-87 front bumper strip slight damage $50
Where abouts in Canada are you.?
1-Used Pvc block $5
Updated Parts List still for Sale
1-Complete used set Kirbans rear seat braces with hardware $50
1-Complete used original air box with hose and used KN air filter $100
1-Used washer bottle $10
1-Used Pvc block $5
Hello
Is the antenna still available? And were in Ontario are you located? Shoot me a pm
power antenna,cd with harness,2 3.8 badges still available I'm located in On as well.
1-Used Pvc block $5
Do you have any of these parts still available?
1-Used Pvc block $5
Heres a pic.
Not sure what its called but the steel lines that connect the vacuum lines to the vacuum block, would you have any of those?
