Originally posted by kurst
woohoo, first post over here. I'm an ex-mustangman and I'm looking into getting a new project car..... and to be honest I want a grand national.
-What are the weak points? Rear end, fuel system, crank, rods, pistons, etc?
I find it hard to believe everybody here has stock internals running like 23psi of boost and not blowing stuff up.
You've gotten a lot of great advise so far, and as far as running high boost on stock internals. It really is quite easy to do with a proper state of tune.
My motor (Never broke) was always running nothing less than 25# of boost at the track, and a lot more timing than most.
It is/was TOTALLY un touched internally. Up untill the 150,000 mile point, I never so much as had a valve cover off. My mods were all external and were limited to: A good fuel pump/s, larger turbo (TE-44), LARGER injectors (presently MSD 50's), and larger front mount intercooler (not sure how much it added, but an intercooler upgrade of some sort is required), a good down pipe, a good race chip, race gas (114-116 octane required), and sticky tires.
The only reason I pulled the motor is because I had a spare setting around collecting dust and wanted to freshen my numbers matching motor.
My present engine is the same formulay! NO internal mods, it's all stock parts. All I did to the new motor was to clean it up (had 9,000 miles), and put in new rod and crank bearings, and a oil pump booster.
That's it!! Still running the same external parts!!
The one weak spot is the tranny (I have broken mine no less than 4 times), but now days it can be made virtually bullet proof (as mine has been, I no longer am able to bust it) and can run into the 9's!
P.S. I must admit, that on this motor, I have busted two head gaskets. But neither as a result of racing. Both were stupid mistakes on my part
![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
