Originally posted by darkfa8
You will need the following to operate the GN ECM/Engine Harness:
1. Battery power, Hot at All times to the Orange ECM Wire that runs upto the battery in the GN harness
2. Power Connections at the C100 connector are for the CCCI Ignition Module, Fuel Injectors, Fuel Pump and TCC lock-up These all require a Hot in On, Start and Run
3. The I/P harness connector which is on the end of the harness where the ECM plugs in has the inputs to the ECM for the VSS and ALDL connector (You don't however need the VSS signal to run the car, though it is required if you want the GN ECM to control Torque Converter Lock-up and/or Cruise Control)
If you have a good harness already, don't go wasting money on another harness.
If you need more specific help in terms of exact pins, I'll pull out my schematics and go through everything with you. Feel free to message me on AIM: steelwindmachine or Yahoo: copper_trace
Its not hard at all to adapt the GN harness to another car. You just have to provide it adaquate power in the proper Ignition modes and that's basically it.
So far, I've done a GN harness in a 87 Monte SS, 89 TTA harness in a 87 TA with a GN motor, and I've also totally customized, stripped down and rebuilt the entire engine harness and most of the interior wiring in my car....no problems.
