GN1 3.5' DP, Coil pack brackets, gauges, Thermostat housing Belt Tensioner
RED LS1
SENIOR MEMBER
GN1 Performance 3.5” down pipe.
- fit and worked well has been on car since 2012
- will require an external wastegate. I believe this internal ones stuck.
- Had modifications in the center and has a small dent. This was when GN1 pipes were hitting the floor board so it was rotated and modified to solve that.
- Includes 3.5 inch cutout to match
- has 02 bung
$295 shipped
Billet Thermostat housing, clamp and 160 thermostat. $30 shipped
OEM coil pack bracket, both parts included $60 shipped.
OEM Belt Tensioner around 80,000 miles I believe $75 shipped
OEM Coolant tube as you see it. Nice shape not all rotted away $75 shipped.
Autometer C2 electric FP gauge Slight wear on bezel it's used but it worked perfect. $ 125 shipped. Costs $259 new.
More pics
I'll take the Billet Thermostat housing, clamp and 160 thermostat. $30 shipped
PM sent
If you will separate........I'll take the coil pack support bracket...shipping to Niagara Falls, NY 14304
(Don't need the coil pack plate)
I
[/QUOTE
ll have to think on that. I don’t want to be stuck with 1/2 of it
I have not messed with it and that's a good question. The car had an external wastegate on it so it has remained inop.
Down Pipe, Thermostat and Fuel Pressure Gauge are sold. Coil pack Brackets and Coolant Tube are available.
