GN1 heads, RJC girdle, stock valve covers, spacers, Champion intake
forcefed3.8's
Buckeye Bullet
Brand new in box RJC Racing 20 bolt girdle, everything as it would be right from RJC, $350 shipped
Champion GN1 heads 8 bolt, ported to a fel pro 1200, blended bowls and runners.They were milled flat (.006), valve grind, new exhaust guides, and valve seals 600 miles ago. I went 9.86@137 on 23psi, 18deg timing, 10.8AFR with these. Can be set up for flat tappet or roller cam, no cracks, ready to run $1700 shipped
Stock valve covers in nice shape. The baffle has been removed from the passenger side for running roller rockers
1 set of RJC racing valve cover spacers for using stock covers and roller rockers with bolts package deal, $115 shipped
Champion ported stock intake, good condition $350 shipped
pics
more
more pics shipping is to the lower 48
heads will come with a set of ARP heads studs for a 109 block
just was wondering did you use the stock valve covers with the gn1 heads? did it clear roller rockers with the spacers thanks
Do you still have the Intake and Heads for sale I would to take them off your hands...?
