The GN1's are port matched to the stock GM intake gasket. (NOT the 1200 Fel-Pro's)
The GN1 heads are also prone to cracking. I've seen many of them crack. (actaully "most" of them, though the later versions claim to have the cracking issues fixed.) I feel that ported iron heads are the way to go if you are planning on never exceeding 10.00 in the 1/4. Champion does a nice job on the stock iron heads, as do MANY other porting guys. (I don't know any women head porters, for the Buick V6, but my wife has ground on them in the past.
) (actually women DO make for good head porters, but just don't ask them if they do "head jobs"!
Well ported 8445 stock heads will get you deep in the tens, and have gone well into the nines at over 138. The weight loss of the aluminum heads is worth while, but probably only on your back, when installing/removing. As stated above which I agree with, completely, the GN1 heads do work well, but if you have a good set of ported irons, you won't gain a significant amount of power. The complete package needs to be evaluated to see where you need to make changes, if any.
The above is: "Just My Opinion."
