GN1 Perf. SS 4-bolt headers & Q-trim 4 bolt exhaust housing
ghall
I have a set of BRAND new SS headers--4 bolt w/ gaskets. These headers are brand new. I milled the header flange for 14 bolt aluminum GN heads--if you have 8 bolt heads, you can't tell once they have been installed--if you have 14 bolt heads, i saved you the trouble. They come with everything pictured--i even have the original box they were shipped to me in.
I also have a tangential .81 4-bolt exhaust housing--freshly grit-blasted and ready to go. Fits original Q-trim wheels, not gtq or hpq.
Price of the headers is $525
Price of exhaust housing is $120
Thanks,
Geoff
Are they dubble wall on the slip joint and v-band connections.
Not really sure what you are asking. You can see the slip joint and v-band's in the photos--if you want any close up photos--just let me know.
Price again is $525/headers
and $120 for the exhaust housing.
Geoff
.81 turbine housing
Is that a garret v-band housing, what size is the q-trim wheel? My exducer is 68mm and inducer is78mm.
I called my buddy who is a precision/garret dealer. According to him, it is a garret housing that will fit your application according to the measurements i took of the housing. If you are interested in the housing, i will send it to you and you can make sure it fits what you have, if not just send it back to me,
Geoff
exhaust housing
Received housing, looks very nice. Will check measurements in the A.M. Thanks
turbine housing A/R.81
All measurements look almost identical to older on-center housing.81, except where I can drop in the center housing to bolt up is not as snug as the older one. Both housings are very clean.
