Jan 15, 2008 #1 D DanielWE4 Member Joined Nov 16, 2005 Messages 41 I wondered if anyone else was having pushrod clearance problems (pushrods rubbing) with stock rocker arms and offset heads? Also, would roller rockers prevent this? Dan
Jan 15, 2008 #2 N Nick Micale Tech Advisor Staff member Joined May 26, 2001 Messages 9,208 Yes and yes, with the larger valves the distance between them is greater than the iron heads. To do the job properly, with the correct valve train geometry, you need to use roller rockers.:smile:
Jan 15, 2008 #3 D DanielWE4 Member Joined Nov 16, 2005 Messages 41 roller rockers Which roller rockers do you recommend that will work for me withour having to fill my heads for pushrod clearance? thanks, Dan
Jan 15, 2008 #4 G GNTIM Senior member Joined Oct 29, 2004 Messages 1,448 T&D rockers here. Great product, not cheap though.
