GNX 088 Running Rough-Help
cbszr1
I did a little cleaning under the hood, removed the original pug wires, inlet pipe,
mass air flow pipe, mass air sensor. I cleaned the wires and wiped down the other parts. When I re-assembled the car was running rough. I have changed plug wires and MAF Sensors, no improvement, thoughts.
Do you know of a GN/ GNX Mechanic In the Charlotte Area.
Bryan
Are you 100% sure that you have the plug wires routed to the correct cylinders? Not that I've ever made that mistake before or anything (cough:cough).
Vacumm Line
Check all the vacuum lines on the motor. You could have knocked on off and it will make a huge difference.
Does it run rough like a dead cylinder? It very well could be something simple like 2 switched plug wires. I'm not saying I've done that before :rolleyes: , but I'm not saying I haven't either...
Bryan
Bryan,
'bout time you showed back up on the TR scene... ;) Give me a call so you can check out our new place. We'll hook up the "beige" car.
K.
