GNX #137 on ebay
That is kida bizarre.. Reserve already met @ 26k... Whats up with the quote? Factory reccomended that the "ceramic" turbo be removed?
Sure, no pictures, 0 feedback seller, Ill give em 50k
true. and 9 people actually bid on this thing. im sure buick recomended changing the gnx turbo to a stock gn turbo cause asc spent all that time on the gnx. why use the better turbo when you can have the stock one?:rolleyes:
when did ASC run out of replacement turbos?? That may be the reason.
I don't know about GM recomending it, but I know that most people that have X's and turn the boost up a bit, change them out because the ceramic blades break under higher boost. Plus the replacement cost is pretty high if not impossible to get.
Sully
