Bought mine from him as well for a tad bit less how ever I did purchase it on ebay.GN restoration is where I got the dash. It cost $2,000 shipped
SignUp Now!Bought mine from him as well for a tad bit less how ever I did purchase it on ebay.GN restoration is where I got the dash. It cost $2,000 shipped
I just looked on there website and there selling now for $2250 and their out of stock right nowBought mine from him as well for a tad bit less how ever I did purchase it on ebay.
Bought mine over a year go, so still good price, can you do me a favor and check the bulb number for the speedo and tach? I want to switch leds and post pic after your installI just looked on there website and there selling now for $2250 and their out of stock right now
Does anyone know how does the one made by GN restoration compare to the one made by World of motorworks[/
Well worth it if they look like yours! I thought it was an oem cluster because you have the turbo gauge with orange and green very hard to findNo it is a reproduction ,calibrated by GN restoration. The LED Lights come from Superbrite lite company. I can't remember the correct part # but don't think it was LED #194 . I got the the invoice put up somewhere in the house, I can see if I can find it if you are interested in buying some bulbs. I do remember one thing there not cheap !!!!
Ok talking with Russ I forgot to hook up boost gauge. I thought it was wired in like the original. What size hose did you use for the boost gauge and where did you splice it in at in the engine compartmentJust finished my pre wired gnx dash install. Everything went right in as it was suppose to. Two problems turn signal indicators are blue (GN restoration must have installed blue pre wired leds) and for some reason boost gauge not working. Talking with Russ right now to correct problems.
Please do post the LED pt# and the source, I too desperately need them...thanksNo it is a reproduction ,calibrated by GN restoration. The LED Lights come from Superbrite lite company. I can't remember the correct part # but don't think it was LED #194 . I got the the invoice put up somewhere in the house, I can see if I can find it if you are interested in buying some bulbs. I do remember one thing there not cheap !!!!
I bought a boost gauge kit from autozone for like 5 bucks, and I believe its connected to the map sensor. Previous owner from 2002 had a boost gauge I just used pre existing. I bought the stewart warner gauge kit, but was the same as the Az one so I retuned it, and my turn signals are blue as well, and I have a very dim service light on, I assume it stays that way to bypass the alternator/battery light issue these cars have.Ok talking with Russ I forgot to hook up boost gauge. I thought it was wired in like the original. What size hose did you use for the boost gauge and where did you splice it in at in the engine compartment
Without painting the inside white, you get DIM light ai dont want to take it all apart so Ill live with the dim light, i dont drive my GN at night.., to much attention...Here the link I purchase my bulbs about three years ago, as mention above if you want the speedo gauge brighter you will have to paint the
inside gauge housing white. The bulbs I install are the {Cool 6100k ] if you want a dimmer white look at the { Warm 2700k }.
superbrightleds.com/ba9sledbulb-5smdled
I'm going to buy the boost gauge kit and I also ordered a few yellow silicone bulb covers. I'll let you know if it works. I'm a little disappointed with these issues. For $1900 it should be perfectWithout painting the inside white, you get DIM light ai dont want to take it all apart so Ill live with the dim light, i dont drive my GN at night.., to much attention...
Did they have blue turn signal indicatorsIf it makes you feel any better, the original factory GNX Dash with SW gauges had the same issues....so you're not alone.
No they did not have blue turn indicators ?? , it did come with blue bright headlights indicator.Did they have blue turn signal indicators
great thank you!!Here the link I purchase my bulbs about three years ago, as mention above if you want the speedo gauge brighter you will have to paint the
Install complete everything working. Speedo off 10 mph. Speedo showing 10mph faster than what car is doinggreat thank you!!
