Going from 305 to a 3800 s2 questions
Goat
I heart Boost and DRs...
Im going to do this in my 84 s10 and Im wondering a few things.
What mounts can I use?
Can I make my th350 work with this?
Wiring harness modifications?
Any help will be grateful I been looking around and kinda exhausted.
Looking at the 98 camaro v8 mount and the v6 mount they pull the same part number and I can then get some ls motor swap plates for my truck and then swap it in if those are the same part numbers.
Im using the oreillys website cause its pulling up a anchor 3064 part number for both...
So I think I can get the s10 ls swap mounts and make it work!
On YB.com you said you had a 5.3 for it? I'd do a 5.3 or lc2 over a 3800 unless you got a lot of Fab skills.
I do got it but I was thinking on being different. Im swapping the 305 out for a vortec headed and cammed 350 today.
