IM going to a bank to bank setup with my new built 109 motor, and i was wondering if im gonna lose anything by switching like cruise control, converter lock up, or anthing else.
You will lose lockup control and a/c cut out under wide open throttle, cruise will work You will have to ground pin a2 to get the a/c to work if the harness is not jumpered. i am running a tcc1 digital performance for lock up for under $200 works killer, better than stock ecm. Now you have to program the fast for cold starts, and hot soak and driveability, so that should keep you busy for a few months.. enjoy
Originally posted by norbs You will lose lockup control and a/c cut out under wide open throttle, cruise will work You will have to ground pin a2 to get the a/c to work if the harness is not jumpered. i am running a tcc1 digital performance for lock up for under $200 works killer, better than stock ecm. Now you have to program the fast for cold starts, and hot soak and driveability, so that should keep you busy for a few months.. enjoy
