good cam to go with setup
I recently wiped my stock cam, so i need to a figure a good cam to go with some ported iron heads with1.77 valves a pt54 turbo and around a 3000-3500 stall, I am trying to do some planning to do all of these things. Also, any opions on this setup and what possible to expect. I was also wondering if anyone knows of some dyno sheets of comparing cams, turbos, etc.... Appreciate it, Thanks
Cam selection isn't that critical. Any of the grinds from Comp, ATR, Crane will work well. The biggest question is roller or flat tappet. I ran the ATR/Crane 212/206 .497/.482 roller last year with a 3500 stall 9/11 and it ran great on the road and track. That cam with your set up would work well too.
Just remember, bigger isn't always better in camshafts. The stock cam has gone super fast and is tiny.
I WAS PLANNING ON GOING WITH A FLAT TAPPET, NOT GOING TO HAVE THAT MUCH MORE MONEY TO INVEST IN A ROLLER CAM. BUT DOES ANYONE KNOW OF SOME DYNO SHEETS COMPARING DIFFERENT CAMS WITH THEIR SET UP.
