Like I said earlier, The one I found for lilspann should work fine. This is from summit and has almost the same specs and it's made to be comp copatible.
Camshaft, Hydraulic Flat Tappet, Advertised Duration 252/260, Lift .425/.440, Chevy, Small Block
Computer-Controlled Compatible - Yes
Lobe Separation (degrees): - 112
Valve Lift with Factory Rocker Arm Ratio: - 0.425 int./0.440 exh. lift
Exhaust Valve Lift with Factory Rocker Arm Ratio: - 0.440 in.
Intake Valve Lift with Factory Rocker Arm Ratio: - 0.425 in.
Advertised Duration: - 252 int./260 exh.
Duration at 050 inch Lift: - 206 int./212 exh.
Basic Operating RPM Range: - 1,000-5,000
Did a cut and paste off Summit after finding the cam.
