good TE style Turbo
TType85
TurboBuick.Com Supporter!
For Sale
70MM Kenne Bell Throttle Body, Upper Plenum and RJC Power Plate $350 + shipping SOLD
No sensors or brackets. Worked great on the car, going back to a stock appearing one.
Turbo, This turbo is a sort-of un-known, i'm working on figuring it out. It came from innovative in the early 2000's. It spools decently quick with a 3K stall 9/11 Kenne Bell converter It is tight and didn't burn any oil. TE Style, Precision .63 a/r exhaust housing. The car went 11.70@117 at 19# of boost on 92 octane and a street chip. I am going to a TA6262 DBB. $425 + shipping
Paypal preferred.
Interested in the turbo, please take some micro-meter measurements of the openings(diameter) of both the turbine and compressor housings and post them up.
i'm getting ahold of a set of calipers tomorrow and will post them up this weekend.
Thanks,
Chris
Turbine housing is 65mm, compressor housing is ~62mm best I can measure with the calipers I have. The inlet tapers down so I went as far down as possible. It measured 63.xx at that point so my best guess is either 61 or 62mm.
I was wrong, pulled the housings and measured.
Compressor is 60mm exhaust measured 63.5-64mm
pictures of the wheels and re-re-measurement....
