lowrollinjo$h
- May 28, 2010
so i just picked up a rough 84 t-type, it needs a lot of help! i put new plugs and wires on it, and did an oil change. after letting it run a little, it is now running rough, and when i give it gas the engine tries to die. the car has a lot of blow back out of the valve cover/oil filler tube (no gasket left at all), but it is also blowing smoke out around the turbo, especially if i rev the engine. the engine idles good aside from the smoke,has a little lifter noise from sitting so long (has been sitting since 1999 supposedly). i go to move the car and of course it keeps dieing. i am new to these vehicles, as everything i have ever worked on has been older and carberated. i'm just trying to get it running decent. i am afraid i will end up doing a complete overhaul, but hopeful it may be a lot of little things wrong making the big picture look bad. i am figuring i probably need to replace the turbo, anyone have a good used one laying around cheap? i would just like to get the car running good, in stock condition for now. eventually i will upgrade/mod it a little, but for now i just need it to run correctly! lol. thanks for any help. -Josh
