govener question
rob85gn
buick_lover
i put a stock tranny in my gn and the speedo is off by abou 20 miles an hour would this make it not go into overdrive?and if so can i put in the govener out of my gn tranny
govener
thanks for the advice it go into over drive but only if i let off the gas all the way then as soon as i push on the gas it jumps right back out
From what what I have heard, you don't want to mix GN tranny parts into a non-performance 2004R unless you swap everything (valvebody, governor, servo). I also don't think that the governor will affect whether it shifts into overdrive or not. Have you checked the adjustment on your TV cable?
As 85_SS stated, you don't want to put a GN (BRF) calibrated governor with a 'run-of-the-mill' valve body. That's one way to assure no WOT upshifts.
To get your speedometer working correctly, just change the governor gear itself. Put the orange gear on the other governor. Then, put the blue 30-tooth driven gear from your GN trans with it.
If the TV cable is adjusted correctly, the no-overdrive condition could be an internal transmission problem like a stuck shift valve or the shift valve calibration doesn't agree with your rear gear/tire size.
There are some dramatically different shift valve arrangements between various model 200-4Rs.
calibrate
how would i be able to calibrate the tranny to shift right i adjusted the cable and the looser i make it the harder it shifts the tighter the tv cable the faster it shifts:confused: :confused:
If you want that transmission to act correctly, you will need to transplant your governor, valve body, spacer plate, boost valves and servo from your original GN transmission.
no joke
nope i need to make a trip next weekend to ny about 450 miles figure change the gears then i will be all set i have a 308 as well i just want to bring the gears closer to match the tranny i am depleted of funds
