There are 2 sets of gears on it one is at the top the lower set runs the speedo. I have the correct speedo gear I just want to know if the upper portions are different?
those are the drive gears and affect the governer speed
, to make small changes for the speedometer correction you need to change the driven gear thats in the end of the speedometer bullet
The different colors are to adjust the speedometer only, they have nothing to do with the function of the governor as they all spin the governor at the same speed. Here is a good reference to figure things out
Thanks Dave. I appreciate that. One more question. The spring on the governor should effect the shift? heavy spring late shift (6000) lighter spring early shift (5600) the numbers are a guess but you get what I mean. Is that correct?
