governor spring vs. stuck valve vs. 2nd gear band
jsta6
John 15:17
Hello.
I did some searching and searching and I am still not 100% clear on what are the differencers in the symptoms of a missing governor spring vs. a stuck valve vs. a fried 2nd gear band...
Can somebody clarify the symptoms of each?
TIA!
no spring no upshift until 4500 plus rpms,bad band is just what it sounds like you have going on.perform the test i pointed out.
