Grill Install
MikeL.
Stay boosted my friends
Does anyone have a method of installing the three bolts that hold the grill to the header panel? My grill is loose and the threaded clip spins when trying to tighten it. Can't determine if the grill gets sandwiched in between the clip then tighten it down? I'd like to do this without removing the header if possible. Can't find much in the search or innerwebs on this. Thanks.
There will be three threaded clips on the top side, that will "sandwich" on the top(threaded side on the top of the hole), bolt goes in from bottom into the threaded clips. Long extensions & a 10mm and you can reach them from below the bumper.
If the threaded clips are spinning, you may have to remove the grill to push them back into place, or you may need new threaded clips. Don't drive them in too far or ya risk cracking the header panel.
