GTA Conversion
bsdlinux
Just Another BLACK Car
I know someone has done the GTA conversion on this board. Just wanted to know what was needed other than obvious...
his name is Steve aka TTA850, and i'll be doing mine in April, what do u need to know?
Mainly wiring harness issues etc....
I know that the tranny cross-member needs to be changed to accept the 200R4. I am not sure about the VSS, if the existing wiring will work.
It also my understanding that the driveshaft will have to be changed.
I was really curious about the wiring harness computer, etc...
Are you using a TTA or a GN/TR harness??
I'm using a TTA harness, it came with the motor when i bought it, you CAN use a GN harness but i hear u have to slice some of the V8 harness to match it up, its really not worth it. You can buy TTA harness but they run like $400-500. And yes if u are gonna run a 200-4r the driveshaft has to be changed
