Originally posted by UNGN
'86-88 GTA fronts look the most like a GNX wheel.
'89-92 Fronts have dimples in the spokes near the rim, close, but slightly different.
GTA fronts have about 1/2 in more BS than GNX Fronts and about 1 in more BS than GNX rears.
GTA rears will only fit in front with spacers and forget about putting them in back. They have too much BS to work, there.
Originally posted by 1badGT
Thanks,
So basically, I can use the rears from a GTA on the front of a GN w/ spacers........and the fronts from a GTA will directly bolt to a GN rear.
OR
use all fronts from a GTA for all 4 on a GN w/out spacers.
Is that correct ?
Thankyou.
the fronts have to be installed w/ a min. 1/4" spacer to keep the wheel from scraping the lower control arm when turning.....personally, i think they sit in way too far to look correct with no spacers at all........not too sure about w/ no flares as my car already had them on.
Originally posted by ajt86
how sure are ya on the 1 for the front and 1.25 for the rear- if your 100% sure itll look good ill take your word for it and order them now- i want it to look good my first shot lol. with those measurements im still putting the rears in the front and vice versa correct? thanks for all your help man
well on the street i run a 255/60/r16 for them in the back, and a 225/60/r16 in the front- should i go with a smaller back spacing or will that be ok? thanks for all the help man i realy apreciate it
