SignUp Now!sams86gn said:I have the GTA wheels on my 86 Gn and they are scrubbing...I have 2 fronts and 2 rears...any suggestions?
x2Run four fronts !
slickj52003 said:did he replace the upper a arm bushings? Had an insident where a guy (me) dummy replaced a arm bushings and put right on left and left on right and had similiar issues. Weird things happen when you try to rush.
don't run longer studs and spacers- that's a recipe for disaster. you can get away with the rears on the front with a 5/16" spacer- i did it for about a year before i got a second set of fronts- but don't run longer studs and a 1/2" or thicker spacer on the rear... if you are gonna do it, do it right, and either find another set of front wheels or put adapters on the rear..
