salvageV6
Daily Driver
- May 25, 2001
My boss at work needs some approx. info. as to what his composite should run. Spec's. appear below.
I would assume 3200LB. vehicle weight for the 1974 model, yeah it still has the big honking bumpers on it.
Trying to get him to sign up for drag day at LVD but he doesn't want to be too slow.
Be kind.
Rims/Tires:
1) American Racing 15” Rims
2) Grand Prix Radial G/T P225/70S15 Front Tires
3) BF Goodrich Comp T/A Drag Radials P275/50R15 Rear Tires
Engine:
1) 350ci V8 XXXXXX
2) Rebuilt 1995 with 30K miles as of 6/01 Installation
3) Edelbrock Performer Series 600 CFM 4bbl Carburetor 8/31/2002
4) Edelbrock Performer aluminum intake manifold 8/31/2002
5) “Mild” Street Cam
6) High Performance Accel Super Coil ACC-140001, 50KV
7) Accel Super Stock Ignition (Spark Plug) Wires, 8mm?
8) Mr. Gasket Headers
9) Flex-a-Lite Stainless Steel Radiator Fan
10) M/T Aluminum Valve Covers
11) Chrome alternator installed 8/31/2002
12) Gas Line, Vacuum Line, Radiator Hose, and Heater Hose Braided Covering
13) Chrome Air Filter Cover, Master Cylinder Cover, Oil-Fill Cap, Water Coolant Neck, Valve Cover Wing Nuts
14) Moroso 7-Quart Deep Sump Oil Pan Installed 10/25/2002
15) Windage Tray
Exhaust:
1) Sidewinders
Transmission:
1) Muncie 1965 M20 Four Speed Manual Installed 6/2001
a. Serial Number: P1211
b. Main Case Casting Number: 3851325
c. Extension Housing Casting Number: 3857584GM
d. Gear Ratios (per http://peachstatechevelles.com/muncieid.html)
i. 1st - 2.56:1
ii. 2nd - 1.91:1
iii. 3rd - 1.48:1
iv. 4th - 1.00:1
v. Rev - 3.16:1
2) Hurst Shifter (Indy model?)
Rear End:
1) 10-Bolt Modified to posi 3.42:1 ratio on 4/2002 (posi-unit installed and ring and pinion gear replaced)
Suspension:
1) X Ton Heavy-duty rear coil springs installed 198?
2) Monroe Sensa-Trac Load Adjusting Rear Shocks with helper springs
3) Lakewood LAK.20463 Ladder Bars
I'd guess 14.8 for a rookie best time.
Rims/Tires:
Engine:
1) 350ci V8 XXXXXX
15) Windage Tray
Exhaust:
1) Sidewinders
Transmission:
i. 1st - 2.56:1
ii. 2nd - 1.91:1
iii. 3rd - 1.48:1
iv. 4th - 1.00:1
v. Rev - 3.16:1
Rear End:
Suspension:
