I have a problem that is running me ragged. I'm usually on top of things when it comes to these cars but this problem is making me pull my hair out bordering on breaking out the plasma cutter.
Here it is: I can set the cam sensor as per spec, and about 10 miles down the road it'll start sputtering and dropping cylinders until it finally dies and has a hard crank. I can get out move the cam sensor till the hard crank goes away and get it running again. I can get it to were the hesitation on rev is gone by ear tighten the cam sensor down and be off....... only for it to happen again on down the road. Bare in mind the car when is running right runs great. It just seems my cam sensor has a mind of its own. Funny thing is this is the 3rd cam sensor the tab has been in place on all three, the caps are good no cracks, the shaft play is good. Background on motor fresh rebuild, new timing chain & tensioner. Again when cam sensor seems set right the car flies that is until it needs to be moved
once its running I can unplug the cam sensor unfortunately I'm running a Thrasher 92 so that fix works barely that is until the signal decays then I'm back to square one on the side of the road dead. Anybody run accross this type of a problem?????? Input needed... thanks. Geoff
![Mad :mad: :mad:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f621.png)
