GW arm install?
HOT & COLD GN
I just got my Global West a-arms, it has no instruction? There are grease fittings in the bag of parts but where do they go? I looked all over the ball joint and there is no place for the fitting. Are you suppose to be able to grease the ball joint on these arms?
Joe Cook
You have to pull the aluminum covers off of the upper ball joints. The ball joints sit down inside the arm. The aluminum covers are held in place with o rings. I had problems with the covers popping off from the grease pressure inside the cavity. I drilled a small hole in the center of each one. You will see what I am talking about after you grease the joints.
