-87 Intake(upper and lower)with fuel rail, and throttlebody with Iac, and tps ,throttle lever- Taken ( need lower intake
-87 Throttle bracket
-87 EGR solinoid with vacuum harness
-87 Waste gate solinoid
-87 Throttle cable
-87 ECM+chip
-87 MAF
-87 spark control module, Fan relay, MAP
-87 coil/ module
-coil brackets(2 brackets)
-pass manifold + cross over
-turbo bracket
- main accessory and alt brackets(both Y and L brackets)- Got
-belt tensioner
-87 alt- Got
-AC compressor- Got
-Power steering
-PS reservior and mounting bracket- Got
-87 down pipe
-87 Pass valve cover
-87 Turbo
-turbo oil feed and oil return lines, with brass adaptor
-87 Waste gate actuator
-turbo shield
-87 engine harness and injector harness and relays
-Intercooler- Got
-Intercooler brackets(2 brackets)- Got
-Intercooler fan- Got
-Intercooler scoup- Got
-up pipe- Got
-all pulleys(crank, water pump, alt, etc.)- Got
-87 crank position sensor
-87 Detent cable
-87 cruise control assembly - Got
-Electric fan- Got
-Rad hold down
-87 AC lines
-Ac line brackets
-Plus all the hardware for all the above parts
Got that from one of the guys on the board.
Excuse all the "-got" and "-taken" Its my check list that I started
