Hall Effect Speed sensor
greeneyegi
Looking for a hall effect to work in conjunction with the VDO speedo setup. Has 2 wires to send signal to ecu.
I need it to pass through speedo cable.
PP ready shipped to 94564
thank you.
thank you.
Nook & Tranny sells them, it screws into the trans and the speedometer cable screws into the sensor. It has two wires coming out the side, one goes to ground and the other to the ECM. Or rather the VSS, brown wire that comes out of the VSS ( green box ) cruise run a wire to the red one VSS. 954-572-8888
