hard launch now late shifts????
turbo john FL
ITS ONLY A SIX SHOOTER
hey guys
i did o power brake launch with my 9/11 l.u. at about 3200 rpm on the street . street tires and now my tranny is shifting late and hard. although it works ok for a while then i have to bring the rpm s up high to get it to kick into next gear. more so going into top gear. i have reset the tranny cable but still doing it .
any ideas at where to look . by the way the tranny was built with a ck high performance rebuild kit about 3k agao
any help here will be appreciated
Sounds like you tossed the governer spring off. Fairly common occurence. If you're lucky, it'll be in one piece in the bottom of your pan. If not, you'll need to get another.
