philosobrad
- Apr 23, 2004
Shaking the bugs out of the fresh rebuild, drove around locally all weekend, adjusted TPS, adjusted FP to recommendations found here. Car really evened out and was very enthusiastic that I'd started getting things right.
Here's the "but"
Drove it at speed on my 50 mile commute to work on 4 lane this morning. Filled with gas to check mileage, etc. etc.........Did fine on the way there at 65mph with cruise on, other than what seemed like a very slight rough running condition.....no SES light, A/F gauge stayed between 13.5 and 14.5 and down to 10.5-11 under boost (12-15lbs). The car really surged when it shifted into overdrive on level highway, but did fine when pulled back into drive......cleared up when boost comes on.
On the way home, however......as I was going up hill in overdrive, the car stalled HARD then settled back down when the boost came up. This happened three times, so I pulled back into drive and seemed to fix the issue, normal boost etc. The car "seemed" to get rich and the boost "appeared" to spike slightly when this happened.
BIG SHOCK was when I got it back into Springfield at the 100 mile mark and it took 9.97 gallons of fuel!! 10 MPG.....What gives?
86 T-type. Fresh rebuild,.030 hypereutectics, 110/110 cam, TA-49 stock actuator, stock downpipe, stock intake, 42.5 injectors w/casper's chip. Stock trans and torque converter.......
			Here's the "but"
