harmonic balancer
turbo buicks
ESADAH!!!
the dude that changed my timing chain said he thinks one of the harmonic balancer bolts was loose and he didnt have a torque wrench to torque it down to spec. if one of the bolts is loose can this cause an engine vibration that feels like a miss? also can a blown HG cause a miss even if not signs of a HG are showing?
first of all there is only one bolt holding it on and yes if it is loose it will cause a miss. The crank sensor takes it s signal off 3 rings on the balancer and if it is loose the rings may not signal causing a miss. Get it fixed asap/
