Have one?
Jerryl
Tall Unvaccinated Chinese Guy
In need of:
Hot Air Valve cover screw with stand-off (DS back)
I'll pm you on where I get all my used hot air parts from. (was asked to not bother giving any feedback to him so I will not post his name or email). I got a couple valve cover bolts from him a while back. Worst case... If you 've still got your bolts, and the stand off portion is broke off. If you're handy with a welder or know someone who is, it would just be a matter of putting the bolt and whatever cut to length threaded rod (or a bolt with the head cut off)in a vise and tacking on a quick weld. Should last a lifetime considering no more torque that is applied to it. I've done this before with a arc welder. Which isn't as clean as a tig or mig. But I just took it to a grinder and removed any slag to make it nice and flush and pretty. :)
