With the cold weather upon us I have been taking the GN out and romping on it pretty hard
Doing this makes me question what is and is NOT good for my tranny.
If you can answer some of my questions I would be all smiles.
1) when the car drops into the last gear at 50ish mph that is actually overdrive right? Is overdrive an actual gear or something else?
2) is it better at 70mph to ease into the boost in overdrive or better to kick it down to 3rd and hammer the gas?
3) is it expecially hard (read: will I break anything) if I hammer the gas at freeway speeds (75) and it drops down into 3rd?
4) at moderate boost levels, say 8 psi, is it ok to let the car shift from 3rd to overdrive on a freeway entrance or should I hold it in D and shift to OD once I am up to speed?
Thanks for any info you can share. Tranny is running great now and I want to keep it that way :smile:
