Bird of Prey
- Sep 30, 2004
hi there
i opened my rear axle cover these days to drain the old, greenish lube and ... of course because i have some "whine" when i'm in Drive and let the car roll. i have a feeling that, when the trans shifts in 2nd gear, the noise disappears. when i run at above 20 mph for example, there is no noise at all.
when i brake down to 5-10 mph and the trans shifts down the noise is again there.
it sounds a bit like a turbine (no it's not the turbo-whine). 100% mechanical noise. could it come from the transmission? any examples given?
matt
edit: i have to add that i refilled my rear with original GM Gear Lube and the LSD additive now.
matt
