Vendor Defendor
Out the window
- Nov 25, 2002
I was having problems about a month ago with my alky kit, sent Steve my control box, he sent me a new one... it worked when I first put it in the car, (well, as far as I could tell the kit could work. it worked when I pressed the test button and it worked when I applied pressure to the line using a air blower) but since the tranny wasn’t in the car I couldn’t truly test it.
I finally have a tranny in the car and its running (woohoo) now, a month later the kit is dead again... I 'hotwired' the pump, directly off the battery and the pump worked just fine. Tried the test button again, no work...... I applied pressure to the boost line, using an air blower w/ a rubber tip... I believe it was working... but couldn’t tell because I left the car running since that’s how Steve told me to do it. So it works when I apply pressure to it via air blower but it doesn’t work when I have the car at WOT... so could I have spliced into an incorrect vacuum line? I thought it was fine to splice into any vacuum line?![Confused :confused: :confused:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
Then, while testing the kit, I noticed that around the up pipe were the bung is for the alky, there seems to be alky leaking out of this area... so I must have a sealing problem in that area.. What can I use to seal that area up with? Any sort of RTV sealer or what?
Could all my problems be that I have spliced into the incorrect vacuum lines? Or could the wiring for the control box to the alky kit be screwed?
