Sep 1, 2014 #1 W Willy Mo Member Joined Oct 31, 2013 Messages 67 So i have an HD WG actuator for my stock turbo but im swapping to a pte6176. Any way to make it work? Or do i need a new one with the right bracket?
Sep 1, 2014 #2 B bison Moderator Staff member TurboBuick.Com Supporter! Joined Dec 19, 2005 Messages 18,053 You would need to modify the bracket and screw the actuator to the bracket. Using two set screws welded to the clamp and 2 new holes in the actuator is the easiest. This assuming you are using a t04e cover on the 6176 BPE2013@hotmail.com
