SignUp Now!It almost looks like GM marked the bolt with this reddish paint to indicate the bolts where torqued, there is also a marking with the same material by one of the push rods, I'll try to post some pics. Thanks, Kyle.GM used something that resembled plumbers putty on the threads because they go into the water jackets. Do the bolts have any markings on the heads? More than likely someone changed a head gasket and didn't put sealant on the threads then put coolant tabs in the radiator to stop the water from migrating past the threads.
Neal
Ok thanks for the info, things are starting to make sence now.When the heads are put on at the factory all of the bolts are tighted at the same time. And yes as I recall the factory TTY head bolts had red thread sealer on the threads and under the head of the bolts.
Just a thought do you happen to have a stock timing set on your motor? The cam gear was made of plastic and after years of running it can break down and leave little slivers in the oil pan kinda orange brown in color. I know the stock head bolts when you torque them down some of the thread sealant comes up to the top of the bolt. I just used a pick to remove the extra.
