head gasket thickness for desired compression ratio
bad v-6
Need to know what thickness of head gasket to get 9 to 1 compression...
109 Block is zero decked, 20 over diamond pistons(off shelf stock), champ alumn heads(46cc), eagle crank(stock replacement).
Thank you.... All replies appreciated.
No way of knowing without knowing two more things, piston/deck clearance and piston dish cc's.
