- Nov 30, 2009
While I was chasing down a exhaust leak I decided to do a compression check . All cylinders were 170 to 173 psi except I believe they are #4 & #6 (pass side middle & rear) which were 150 psi (middle) and 120-125 psi (rear). I checked them 3 times , am I right. If so can you change just one side ??? If I pull both heads should I have them O-ringed ?? What gaskets is everyone using ? Thanks Sam
